Adeunis with LoRaWAN™
Adeunis logo
TagoIO supports most Adeunis devices by providing integration with several LoRaWAN™ networks. TagoIO parses incoming payloads and extracts the measured variable values in real time, making all device data readily available for display or processing in your Analysis.
See Analysis for working with and visualizing your incoming device data.
tip
You can check whether a parser script was added to your device under the tab Payload Parser in your device page.
Adding a device​
To add an Adeunis device to TagoIO:
  1. Go to Devices.
  2. Click Add Devices.
  3. Filter the network by the LoRaWAN™ provider you will connect with.
  4. Pick your Adeunis device from the list.
The exact configuration steps will vary depending on the LoRaWAN™ provider you choose.
LoRaWAN™ providers​
Select one of the following provider-specific integration guides to continue your setup:
Each provider link points to the corresponding TagoIO tutorial for configuring Adeunis devices with that network.
After you have completed the setup above, you will be ready to move forward.
Now, just turn your Adeunis device on and wait for the data to be stored on your device.
Every time the device sends data, the parser will be executed, the extracted data will be stored in the device, and it will be ready to be shown in dashboards.
You can start building your dashboards immediately.
Also, you can create notifications and more advanced scripts as needed.
