Adeunis with Sigfox
TagoIO supports most Adeunis devices by providing an integration with the Sigfox backend. Incoming messages from Adeunis devices are parsed in real time so measured variables are extracted and made available to TagoIO for display in widgets and for processing.
Adeunis + Sigfox + TagoIO diagram
All data sent by your device will be readily available to be displayed in widgets and processed in your Analysis.
info
You can check if a parser script was added to your device under the tab "Payload Parser".
Adding a device​
To add an Adeunis device in TagoIO:
  1. Go to Devices.
  2. Click on "+ New Device".
  3. Filter the list by network and select "Sigfox".
  4. Pick your specific Adeunis device from the list.
Integrate your Adeunis with TagoIO​
  1. Turn on your Adeunis device and wait for the data to reach your TagoIO Device.
  2. Each time the device sends data, the parser will be executed automatically, extracting the measured variables and sending them to the device.
  3. The extracted data is then available in widgets, dashboards, and can be processed further.
You can start building dashboards immediately: Dashboard Overview.
You can also create notifications or write advanced scripts to process the data:
If you have questions about configuring your account for Sigfox and TagoIO, read the article about SigFox.
