Markdown Guide
Emphasis​
Use Markdown to emphasize text:
**bold**
_italics_
~~strikethrough~~
Additional emphasis examples:
  • Italic using underscores: _italic_
  • Strikethrough with four tildes: ~~~~strikethrough~~~~
Headers​
Examples of header levels:
# Big header
## Medium header
### Small header
#### Tiny header
Lists​
Unordered list:
- Generic list item
- Generic list item
- Generic list item
Ordered list:
1. Numbered list item
2. Numbered list item
3. Numbered list item
Inline link example:
[Text to display](http://www.example.com)
Quotes​
Block quote example:
> This is a quote.
> It can span multiple lines!
Images​
Need to upload an image? TagoIO Files can help you with that.
Example Markdown for an image:
![Alt text](path/to/image.jpg)
Tables​
Basic Markdown table example:
| Syntax | Description |
| Header | Title |
| Paragraph | Text |
Additional tables from the legacy guide:
| Column 1 | Column 2 | Column 3 |
| John | Doe | Male |
| Mary | Smith | Female |
Or without aligning the columns...
| John | Doe | Male |
Displaying code​
Inline code example:
Use backticks for inline code: var x = 1;
Fenced code block example (JavaScript):
function greet() {
console.log("Hello, world!");
Additional code examples from the legacy guide:
Inline code:
`var example = "hello!";`
Spanning multiple lines:
alert(example);
References:
  • See the TagoIO Files interface for uploading images: TagoIO Files
