Multiple Axes in Chart Widgets
All chart-type widgets in TagoIO can be configured to display more than one Y‑axis. The widgets that support this feature include:
Adding multiple axes to your chart​
To add multiple axes to a chart widget:
  1. Open the widget's edit page.
  2. Under the Options section, open the Y‑axis subsection.
  3. Click the Multiple Axes button to add and configure additional Y‑axes.
Multiple axes
After clicking the Multiple Axes button you can associate one or more variables with each Y-axis. By default all variables are automatically assigned to the y1 axis unless you change it. Only variables that have been added in the widget's Data Sources section can be selected here.
Once you have configured the axes, click Confirm to preview the changes and then Save to apply them.
Notes:
  • After enabling multiple axes, you can assign different groups to specific Y‑axes so each groups scales appropriately.
  • Use the Y‑axis settings to configure labels, units, and axis position (left/right) for each axis. You can also hide a label if desired.
