VU Meter Widget
VU Meter gauges display the variable in a velocimeter-style gauge.
Three VU meters example
This widget also accepts features like metadata that can be set in your variable data.
Creating your own​
To add the VU Meter widget to your dashboard, choose the VU Meter widget from the widget list and customize it to your preference. You can edit the widget using the options located on the right side of the widget.
'Data Sources' Field​
This field is dependent on the type of dashboard you are using; the difference is explained below.
1.1 'Data Sources' for Normal Dashboards​
From the option Data Sources on the right menu, select one device from your list of devices and the variable that contains the data.
1.2 'Data Sources' for Blueprint Dashboards​
From the option Data Sources on the right menu, add the Blueprint device and input the name of the variable that contains the information.
info
When using a Blueprint dashboard, the field Variable will list variables to be picked using the currently selected blueprint device.
