Payload Parser Troubleshooting
When using the Payload Parser on TagoIO, you may encounter common problems that prevent the parser from decoding your device data correctly. When the parser stops, the data will not be saved to TagoIO. These problems are usually related to mistakes in how the payload parser code is written, but they can be easily fixed.
For updates on system status, visit the health status page.
Common Issues​
1. Function Parse Error: Payload Parser Terminated Unexpectedly​
This happens when the Payload Parser encounters an error in code that is not formatted correctly and stops working. For example, using a plain string as an error, like:
  • throw "my error message"
can cause the parser to stop unexpectedly.
Fix:
  • Use the proper JavaScript Error class when throwing errors. The Payload Parser uses JavaScript, so create errors like this:
throw new Error("my correct error message");
This method provides a clear and detailed error message, making it easier to identify and fix the problem in your code.
2. "your_variable" is Not Defined​
This error appears when the Payload Parser tries to use a variable that hasn't been declared. For example, writing:
  • temp = payload.value
without first defining what temp is will produce a "not defined" error.
Fix:
  • Always declare your variables before using them with const, let, or var. This prevents the "not defined" error and avoids creating accidental global variables. Examples of variable declaration:
// Example 1
const temp = payload.value;
// Example 2
let temp = payload.value;
// Example 3
var temp = payload.value;
