Deleting Data
info
When making a request to the TagoIO API, you must also specify the appropriate regional endpoint. Check out the available regions: API documentation
Endpoint​
DELETE https://api.<region>.tago.io/data
Headers​
  • Authorization: Your device token
Example header format:
Authorization: <DEVICE_TOKEN>
Optional Query Strings​
Use the same query strings you use to get data to select which data will be deleted. The available optional query string parameters are:
KEYTYPEDESCRIPTION
querystringPre-defined by TagoIO
qtystringMaximum number of data to be returned
start_datestringStart date
end_datestringEnd date
variablestringFilter by variable
To delete data, TagoIO uses the same query string parameters used to get data; for more details about each query, see here.
Examples​
  • Delete the last 99 items from the variable temperature https://api.<region>.tago.io/data?variable=temperature&qty=99
  • Delete the last item from the variable temperature https://api.<region>.tago.io/data?variable=temperature&query=last_item
  • Delete the last value from the variable temperature (requires the _value_ attribute on the variable object) https://api.<region>.tago.io/data?variable=temperature&query=last_value
  • Delete the last location from the variable temperature (requires _location_ attribute on the variable object) https://api.<region>.tago.io/data?variable=temperature&query=last_location
  • Delete data by period https://api.<region>.tago.io/data?variable=temperature&start_date=2014-12-25&end_date=2014-12-26
  • Delete the last value from an array of variables https://api.<region>.tago.io/data?variable[]=temperature&variable[]=pressure&query=last_value
tip
Make sure your request is DELETE and not POST when trying to delete items. Posting data is relatively instantaneous, while deleting data can take between 10 and 30 seconds to complete.
Rate Limits​
When executing requests to TagoIO, you will have a limit on the number of requests that can be made during a certain time period. Read more about our Rate Limits.
