Grouping Variables
It is expected that most devices will send more than one variable at a given time. When visualizing the data, users often want those variables synchronized for each sample period.
For example, a device may send GPS location, speed, and voltage variables at a certain frequency. If those variables are acquired and sent with exactly the same timestamp, the user can visualize all three together at each time sample. However, if there is any delay between them (timestamps of the variables do not match exactly), the system cannot group them correctly "by time".
To solve this, include a group field in the JSON for each sample. A batch of acquired variables can be synced by adding the same group value to their samples. For example:
- The first acquisition could have
group = 0001for GPS location, speed, and voltage. - The second acquisition could have
group = 0002, and so on.
When visualizing these batches of data combined in a Table or Map, select the option "Group by group" to view variables grouped by their group value rather than by timestamp.
To learn how to add the group field in the JSON, see the API documentation.
