Sending Data to Device
TagoIO supports two-way communication with devices. Below are the main options for sending data from your application to a device.
Methods to send data​
Reading data from TagoIO​
Devices can also retrieve data from TagoIO using different endpoints depending on the type of data needed:
Best Practice: Use configuration parameters for device settings; use the data endpoint for measurements.
