Getting Data
info
When making a request to the TagoIO API, you must also specify the appropriate regional endpoint. Check out the available regions here: API documentation (link included in the original article).
Headers​
Include your device token in the Authorization header.
Authorization: Your-Device-Token
Endpoint​
Use the regional data endpoint:
GET https://api.<region>.tago.io/data
Query Parameters​
The following querystring parameters are supported:
KeyTypeDescription
variablestring or arrayGet variables
querystringPre-defined by TagoIO
qtystringMaximum number of data points to be returned
start_datestringStart date (e.g., "1 day" or ISO string)
end_datestringEnd date (e.g., "1 day" or ISO string)
detailboolInclude additional JSON fields in the returned results
Response Example​
Below is a sample response when no query parameters are supplied:
"status": true,
"result": [
"id": "547e42847dbf3af122c02582",
"location": {
"coordinates": [41.878876, -87.635915],
"type": "Point"
"time": "2014-12-02T22:51:48.005Z",
"variable": "location"
"id": "547e353d7dbf3af122c0257d",
"time": "2014-12-02T21:55:09.301Z",
"unit": "%",
"value": 32,
"variable": "fuel_level"
"id": "547e41f97dbf3af122c02580",
"time": "2014-12-02T22:49:29.777Z",
"unit": "psi",
"value": 25,
"variable": "oil_pressure"
Variables​
The variable parameter specifies which variable(s) to return. Example for a single variable:
https://api.<region>.tago.io/data?variable=temperature
To request multiple variables, use an array syntax:
https://api.<region>.tago.io/data?variable[]=temperature&variable[]=pressure
Query​
The query parameter triggers predefined functions. Only one query can be used per request.
QueryDescription
last_itemReturns the most recent data point based on _time_.
last_valueReturns the most recent data point that contains a _value_ field.
last_locationReturns the most recent data point that contains a _location_ field.
Example:
https://api.<region>.tago.io/data?variable=temperature&query=last_item
Quantity​
The qty parameter limits how many results are returned (default 15).
Example to retrieve 99 records:
https://api.<region>.tago.io/data?variable=temperature&qty=99
Start and End Dates​
Use start_date and end_date to filter data between two timestamps. They accept various formats, including relative time expressions.
Example:
https://api.<region>.tago.io/data?variable=temperature&start_date=2014-12-25&end_date=2014-12-26
If the interval contains more than 15 items, add qty to increase the limit.
Date Formats​
FormatExample
ISO string2014-12-25T23:33:22.000Z
Human readable2014-12-25 23:33:22
Relative1 day, 1 month, 1 year
Relative dates are calculated from the current time.
Rate Limits​
When executing requests to TagoIO, you will have a limit on the number of requests that can be made during a certain time period. Read more about our Rate Limits.
