AI Dashboard
An AI Dashboard is a dashboard you build by describing it. Tell TagoAI the charts and layout you want, and it builds the page with data from your devices. To change it, ask again in the prompt bar or the TagoAI Chat. Run users can open it in TagoRUN and, with permission, shape their own version.
Admin view of an AI Dashboard called Cold Rooms. A prompt asking for each room's last temperature and a 24-hour chart is typed in the prompt bar and sent, and the layout fills in with a temperature card for each room and a 24-hour chart.
Where to use it​
ContextSupport
AdminCreate, generate, refine, and view.
TagoRUNSigned-in Run users view it, with data from the devices they can access. See In TagoRUN.
TagoAIRequired. With AI turned off for the profile, AI Generated leaves the create dialog and existing AI Dashboards stop loading data.
Share public, Distribute, EmbedNot supported. Use Normal or Blueprint when you need them.
What you get​
  • Prompt instead of placing widgets. Describe the dashboard in plain language and TagoAI produces the layout. On Normal and Blueprint you build the same kind of view by adding widgets to a grid.
  • Refine by prompt. Change layout, colors, charts, and text without dragging widgets or rebuilding the page. See Generating AI Dashboards with Prompts.
  • Live data without regenerating. Widgets reload on their own when their devices receive data. Generate again only to change the design. A device you add to a tag the dashboard reads shows up within 10 minutes.
  • Versions. Each change that alters the layout saves a version you can restore.
How it works​
  1. Create an AI Dashboard: pick AI Generated in the create dialog.
  2. Describe what you want in the prompt bar. TagoAI generates the layout, and Admin loads data so charts and tables fill in.
  3. Refine with more prompts. Widgets update on their own when the dashboard's devices receive data.
  4. Grant Run users access when the dashboard is ready for them.
To build or refine a layout from code, for example from an Analysis, use Generate AI Dashboard in the API.
In TagoRUN​
A Run user opens an AI Dashboard in TagoRUN and sees data only from the devices they can access. A Run user with AI dashboard generation can also change it with a prompt, which creates their own version: a personal dashboard.
Compared to other dashboard types​
TypeHow you build itPresentation
NormalDrag-and-drop widgets on a gridWidget grid
BlueprintSame grid, slots resolve devices at runtimeWidget grid
AI DashboardNatural language generate and refineFull-page generated
Custom DashboardUpload HTML; use saved queries or Analysis EndpointsFull-page uploaded
In the create dialog, Normal and Blueprint are the two kinds of Widget Dashboard, an AI Dashboard is AI Generated, and a Custom Dashboard is Custom HTML.
Use Normal or Blueprint when you need share, distribute, Embed, or control over each widget. Use an AI Dashboard to generate a full-page layout from a prompt, and a Custom Dashboard for a full-page layout you author and upload yourself. Both full-page types open in Admin and in TagoRUN.
Prerequisites​
  • TagoAI turned on for the profile. See AI availability.
  • Devices with the data you want to chart. The generator reads device names, tags, and variables, so clear names give better layouts.
Next steps​
