Embedding Widgets to Your Website
Embedded widgets are a convenient way to display your data from TagoIO in another application. By generating the embedding code on a widget, you can add that widget to your website or any other application.
warning
Embedding is only supported for widgets on a normal dashboard. Widgets on a Blueprint dashboard cannot be embedded.
Example
Below is a simple example of using embedded widgets in your own website.
How to Generate the Embedding Code
Open the dashboard that contains the widget you want to embed, and click the gear icon on that widget.
In the widget settings, navigate to the Embed Widget tab, click Generate Code and then click Copy.
- Paste the copied code into your website's HTML where you want the widget to appear. The data from TagoIO will update in real-time for anyone who views the page!
Something missing from this page?
