Widget Header
The widget header enables you to add customized buttons to the header of your widget to improve the flow of your dashboard.
Header buttons (UI fields)​
The header buttons panel includes fields to configure each custom button:
  • Icon: Icon displayed on the button.
  • Button text: The label shown on the button.
  • Color: Button color.
  • Layout: Button style (e.g., Fill, Outline).
  • When clicked: Action performed when the button is clicked (for example, "Open widget").
  • Resource: Target resource for the action (for example, a specific Form).
Example entry shown in the UI:
  • Icon: plus/add icon
  • Button text: Add data
  • Color: (blue sample color)
  • Layout: Fill (or Outline)
  • When clicked: Open widget
  • Resource: Form #1
Additional UI controls:
  • Add and remove buttons (+ / −)
  • Cancel and Confirm buttons for the header configuration dialog
Header buttons configuration panel showing columns Icon, Button text, Color, Layout, When clicked, and Resource
Additional configuration notes​
  • The widget header is enabled for all widgets. You can configure it by selecting the Header tab in your widget configuration.
  • A maximum of 3 buttons can be added per widget.
  • Icon: Optional icon displayed to the left of the button text. If there isn't enough room, only the icon will appear.
  • Button text: No character limit, but longer text consumes more space; keep it short for better layout.
  • Color: The button's background color; the text color is automatically adjusted for optimal contrast.
  • When clicked: Choose an action (e.g., Open widget, Navigate to URL, etc.). You can select one of three options.
If you use the Open widget action, consider hiding that widget in a Hidden tab. This keeps it out of view while still allowing users to open it via the header button.
