Cylinder Widget
Cylinders are simple and useful widgets that visualize values relative to a defined range (with maximum and minimum limits) using a cylinder gauge.
Cylinder widget examples
This widget also accepts features like metadata that can be set in your variable data. (Refer to the Metadata documentation for details.)
Creating your own​
To add the Cylinder widget to your dashboard, choose the Cylinder widget from the widget list and customize it to your preference. You can edit the widget using the options located on the right side of the widget.
Data source configuration​
The Data Sources field allows you to select the device and variable that will feed data into this widget.
  • For normal dashboards, choose a device from your list and then pick the variable that contains the data.
  • For Blueprint dashboards, add the Blueprint device and enter the name of the variable.
This widget works for both Normal and Blueprint dashboards.
Level labels​
Level labels appear as dashed lines inside the cylinder and can represent limits or divisions. They can be set dynamically by variable data, allowing you to highlight thresholds directly on the gauge.
