TagoRUN Overview
The Run module allows you to create and deploy your solution using a customized logo, colors, URL, signup page, email messages, and more.
Run works synchronized with the Access and User management modules. When you configure and deploy your solution, a domain will be created for your application so that users can sign up.
Run module screenshot
info
By default, your URL may be a subdomain of run.tago.io (for example, mycompany.tago.run) or a fully customized URL using your current company domain (for example, portal.mycompany.com).
With Run you can set up three main things:
  1. Your Run (Application portal)
  2. Your Sign up page
  3. E-mail templates
Your Run (Application portal)​
Go to the Main Configuration and Domain tabs to configure the title and subtitle of your application, add a favicon (browser icon) and logo, and edit the colors used in the navigation bar.
