AI Credits
AI Credits are prepaid funds on your account that pay for AI models charged by usage. You load money onto the account first, and each request to a TagoIO catalog model debits the balance based on the model price and the size of the request.
Credits are separate from your TagoIO plan. Only paid models from the AI model catalog spend them. The free model never touches your balance (it runs on the TagoIO side within its monthly allowance, on every profile), and a profile running its own AI provider is billed by that provider instead.
info
Free chat is not unlimited: the free model has a monthly request quota per profile. See TagoAI Service for the plan numbers, and the AI model catalog for the free model.
The financial terms at a glance:
TermValue
Purchase range10.00 to 1000.00 per purchase
Service feeAdded to the card charge, not credited to the balance; the Admin shows the current rate
ExpirationOne year after the purchase that created the credits
CurrencyUSD or EUR, fixed when the wallet is created
Spend capOptional, per profile, per calendar month (UTC)
AI Wallet Budget tab with the credit balance, automatic top-up settings, and profile spend caps
The wallet​
Your credit balance belongs to the account, not to a profile. Every profile in the account draws from the same balance, and the only per-profile control is a monthly spend cap. There are no per-profile balances or allocations.
The wallet page shows:
  • The current balance and its currency.
  • How many purchases still hold unspent credits, and the date the next batch expires.
  • The automatic top-up configuration.
  • A history of every movement: purchases, spending, expirations, and adjustments issued by TagoIO support.
Currency​
The wallet currency is set when the wallet is created, based on your account region: USD for US accounts and EUR for EU accounts. It cannot be changed afterwards, and TagoIO does no currency conversion. Prices, purchases, caps, and card charges all use that single currency.
Buy credits​
Before buying credits, add a default card under Payment Methods. Purchases always charge the default payment method saved on your account.
To buy credits:
  1. Open the AI wallet.
  2. Select Top up.
  3. Enter an amount from 10.00 to 1000.00.
  4. Review the credit amount, service fee, and total card charge.
warning
The service fee is added to the card charge and is not added to your AI Credits balance. For example, buying 30.00 in credits adds 30.00 to the wallet and charges the card 30.00 plus the displayed fee. Review the total card charge before confirming the purchase.
  1. Confirm the purchase.
After the payment succeeds, the purchased amount appears in the wallet balance. The service fee appears in the payment breakdown but is not added to the credit balance.
If the purchase result does not appear​
If the page closes, times out, or does not show a result:
  1. Return to the AI wallet and check the balance and transaction history.
  2. If the purchase appears, do not start another purchase.
  3. If the Admin presents a retry option for the pending purchase, use that option instead of starting a new purchase. Retrying the same purchase cannot charge your card twice.
warning
Starting a new purchase creates a separate payment. Only use the retry action associated with the original purchase.
Credit expiration​
Credits expire one year after the purchase that created them. Spending always consumes the credits closest to their expiration date first, so the oldest credits leave the wallet before newer credits.
The wallet page shows the next expiration date. Expired credits are removed from the balance and appear in the history as an expiration entry. Expired credits are not refundable.
Automatic top-up​
Automatic top-up buys credits for you when the balance runs low. You set:
  • Threshold: the balance below which a top-up is triggered.
  • Amount: how much to buy, within the same range as a manual purchase (see Buy credits). The purchase service fee applies the same way.
For example, if the threshold is 20.00 and the top-up amount is 50.00, TagoIO schedules a 50.00 purchase after the balance falls below 20.00.
A scheduled job checks wallets every few minutes, so a top-up happens shortly after the balance dips below the threshold, not at the instant of the request that crossed it. A request that arrives before the top-up lands can still fail for insufficient credits.
When a top-up fails​
Automatic top-up uses the saved default payment method. When the charge fails, for example because the card was declined or removed:
  • The balance stays where it is, and requests to catalog models keep failing for insufficient credits.
  • Automatic top-up stays enabled, and TagoIO tries again on later checks while the balance remains below the threshold.
  • TagoIO does not email you when a charge fails.
  • Successful top-ups appear in the wallet history; a failed charge does not create a history entry.
Keep a valid card on the account so top-ups can go through.
Set a monthly profile spend cap​
A spend cap limits how much a single profile can spend in a calendar month. It does not reserve part of the account balance for that profile; a capped profile still competes for the same balance as every other profile.
To configure a cap:
  2. Find the profile spend cap settings.
  3. Select a profile.
  4. Enter the monthly cap, or clear it to remove the cap.
  5. Save the setting.
The counter resets at the beginning of each calendar month in UTC. When a profile reaches its cap, its requests to catalog models are refused until the month rolls over or you raise the cap.
Where the cap applies​
Environment and model pathDoes the profile spend cap apply?
TagoIO catalog model on TagoIO CloudYes, on AI Credits spending
Free modelNo; the monthly allowance applies
Own-provider model on TagoIO CloudNo; your provider's limits apply
Instance-provider model on TagoDeployYes, based on the catalog value
Resolve wallet and spending errors​
MessageWhat to do
Insufficient AI creditsThe account balance cannot cover the request. Top up the balance in the AI wallet, or enable automatic top-up.
This profile has reached its monthly AI spend capThe profile hit its monthly cap. Raise it in the spend cap settings or wait for the next calendar month.
Top-up amount supports at most 2 decimal placesThe purchase amount has more than two decimal places. Enter an amount with at most two.
Cannot top up AI credits without a payment methodNo default card is saved on the account. Add one under Payment Methods.
TagoDeploy behavior​
TagoDeploy does not use an AI Credits wallet.
CapabilityTagoIO CloudTagoDeploy
AI Credits balanceAvailableNot available
Credit purchasesAvailableNot available
Automatic top-upAvailableNot available
Provider billingTagoIO or your configured providerThe instance provider account
Usage statisticsReport charged spendReport catalog value as a usage meter
Profile spend capEnforced on AI Credits spendingEnforced against the catalog value
On TagoDeploy, paid-model usage runs on the instance's own provider credentials and is priced from the instance catalog for metering and cap enforcement. TagoIO bills nothing for it; the instance's provider account pays for the actual usage.
