Running Analysis as External using Deno
Analysis enables you to create custom applications on TagoIO. When creating an Analysis, you can choose to run it on TagoIO or externally on your own infrastructure.
Running an Analysis externally with Deno provides several advantages:
  1. Development Experience: Full IDE support with TypeScript, debugging capabilities, and Deno's built-in development tools.
  2. Security: Keep sensitive code on your infrastructure when compliance or security policies require it.
  3. Performance: Direct control over the execution environment and resource allocation.
1. Install Deno​
Deno is a secure runtime for JavaScript and TypeScript built on V8, Rust, and Tokio. It includes TypeScript support out of the box, a built‑in formatter and linter, and secure defaults. Learn more about Deno.
Visit the Deno Installation Guide for platform‑specific instructions.
2. Create your Analysis​
2.1 Create a new file for your Analysis​
For this example, call it analysis.ts:
import { Analysis, Device, Utils } from "npm:@tago-io/sdk";
import { DateTime } from "npm:luxon";
async function myAnalysis(context: any) {
// Your analysis logic here
console.log("Running external Deno analysis");
console.log("Context:", context);
const now = DateTime.now().toISO();
console.log("Current time:", now);
Analysis.use(myAnalysis, { token: "MY-ANALYSIS-TOKEN-HERE" });
3. Configure Permissions​
Deno runs with secure defaults. Create a deno.json configuration file to specify permissions:
"tasks": {
"start": "deno run --allow-net --allow-env analysis.ts"
The --allow-net flag permits network requests to TagoIO APIs, and --allow-env allows reading environment variables.
4. Running your Analysis​
Replace MY-ANALYSIS-TOKEN-HERE with your actual Analysis token. You can get this by:
  1. Access your Analysis page at TagoIO
  2. Select External for 'Run the scripts from'
  3. Copy the generated token
For better security, use environment variables:
const token = Deno.env.get("ANALYSIS_TOKEN") || "MY-ANALYSIS-TOKEN-HERE";
Analysis.use(myAnalysis, { token });
Run your Analysis:
# Using the task defined in deno.json
deno task start
# Or directly
You should see output indicating the Analysis is connected and waiting for triggers.
More Examples​
Check our Deno Analysis examples.
You now have everything needed to run external Analysis with Deno, using TypeScript support, remote imports, and modern development tools to create TagoIO applications.
