Serial Number Format
You can specify a custom mask/format for your Network's Serial Number.
To create your format, use the characters defined below.
Definitions​
SymbolMeaning
FAllows characters that range from a-f and digits that range from 0-9
PAllows any alphanumeric character (a-z, 0-9)
0Allows only digits (0-9)
AAllows only characters (a-z)
Examples​
  • To create a serial number limited to digits only, use the following format: 0000.
    This format accepts exactly 4 digits in the serial number.
    0000
  • To use 16 characters in your serial number, allowing characters that range from a-f and digits that range from 0-9, use the following format:
    FF-FF-FF-FF-FF-FF-FF-FF
    This would allow combinations like:
    08-86-AB-56-82-6C-F2-EE
