Tags System
Tags are a flexible and powerful way to organize and label your assets within TagoIO. Tags let you manage access and identify key components such as Devices, Actions, Analysis, Dashboards, and Users & Access rules.
Operating like key–value pairs, tags enable you to assign relevant metadata to your assets, such as:
- names
- descriptions
- categories
- locations
- customers
- products
- and more
1. How to use tags
Tags can be assigned to a wide range of components within TagoIO. They are typically available through a designated "Tag" tab when configuring assets that support label assignment.
Tag parameters
| Parameter | Description |
| Key | Name of the parameter used as reference; you may also select an existing key. |
| Value | The value you want to assign to your asset. |
Maximum number of tags per asset
The maximum number of tags that can be attached to a single asset is 30. If you attempt to add more than this limit, a notification will appear indicating that the maximum capacity has been reached.
Delete protection
You can protect critical resources from accidental deletion by adding a special tag:
- Key:
_delete_protection_ - Value: A custom error message to display when deletion is attempted
When this tag is present on a resource, any attempt to delete it will be blocked and result in an error or warning that you can customize.
Managing tags
Tags can be managed from several sources:
- TagoIO Interface – Manually add or edit tags by clicking the asset and then selecting the Tags tab.
- Analysis SDK – Programmatically add or edit tags from an analysis script using methods such as
account.devices.edit()oraccount.actions.edit(). - TagoIO API – Use REST API endpoints for each asset type to add or edit tags by sending HTTP requests with JSON payloads containing the tag information.
Common use cases
- Access Management: Assign a tag like
_role: Manager_to a user group and grant them access to all devices tagged with_customer: ACME Inc._. - Blueprint Dashboards: Create a dashboard that allows users to switch between devices by selecting any device with a specific tag, e.g.,
_device_type: Temperature Sensor_.
(Example UI: the screenshot shows a "Tags" tab with a table-like interface where you can add a tag key and enter its corresponding value. There are controls to add or remove tag rows and a Save button.)
