title: "Sens'it with Sigfox"
description: "This article explains how to integrate Sens'it v2 and v3 devices with TagoIO using the Sigfox backend, how to activate a Sens'it devkit, and how to add the device to TagoIO so its data can be displayed or processed."
# Sens'it with Sigfox
TagoIO is fully integrated with Sens'it v2 and v3 devices. This integration uses
the Sigfox backend and parses incoming messages to extract measured variables in
real time. All data sent by your device will be available to display in widgets
or to process in your Analysis.
![Sens'it + Sigfox + TagoIO Connectivity Diagram](/docs_imagem/tagoio/tutorials-sensit-sigfox-network-architecture-diagram.png)
## Prerequisites
- Sens'it device (v2 or v3)
- Sigfox developer access (to activate the devkit)
- TagoIO account with access to add devices
## Activate the Sens'it devkit
1. Activate your Sens'it as a devkit. As a developer, you must request access to
   the Sigfox Cloud to use devkit mode.
2. Request access from the Sigfox Buy website: https://buy.sigfox.com/ and
   follow their instructions to activate the devkit.
3. Once the devkit is activated, the device will be able to send data through
   the Sigfox network for testing.
## Add the device to TagoIO
1. In TagoIO, go to [Devices](https://admin.tago.io/devices).
2. Click on "+ New Device".
3. Filter the network by "Sigfox" and choose your Sens'it device from the list
   (select v2 or v3 accordingly).
4. After adding the device, incoming data will be parsed by TagoIO and become
   available for widgets and Analysis.
## Dashboard Setup
After adding the device, click on the newly created dashboard in the left menu
and associate it with your Sens'it device. Turn the device on; data will arrive
automatically into the bucket and be displayed in widgets.
## Data Storage
Every time the device sends data, the parser is executed, the extracted data is
sent to the device's data, and it will be ready to be displayed in dashboards or processed in [Analysis](/docs/tagoio/analysis/).
## Custom Parsing (v2)
If you are using Sens'it v2, you may want to edit the **parse function** in your
device to extract variables from more modes. Check the complete payload
documentation: [Payload Parser](/docs/tagocore/device/payload-parser.md) and the
Sigfox developer guide for detailed information.
## Advanced Features
You can create **notifications** and advanced **scripts** as needed:
- Notifications: [Notifications](/docs/tagoio/tagorun/notification.md)
- Scripts / Analysis: [Analysis Overview](/docs/tagoio/analysis/)
## Notes
- The integration supports both Sens'it v2 and v3 devices.
- Ensure your Sigfox devkit is properly activated before registering the device
  in TagoIO.
- For any specific Sigfox backend configuration or Sigfox Cloud settings,
  consult Sigfox documentation or the Sigfox Cloud console:
  [Sigfox](/docs/tagoio/integrations/networks/sigfox.md).
