title: "Displaying Locations on a Map with TTN LoRaWAN"
description: "This article explains how to send location data from The Things Network (TTN) to TagoIO so that device locations are displayed on a Map widget, including the required JSON payload format and the steps to add the 'location' variable to a dashboard map."
# Displaying Locations on a Map with TTN LoRaWAN
If you have a custom payload format decoder at TTN (The Things Network), you can send your payload variables directly to TagoIO.
To display locations on a Map, your data needs to be sent inside a "location" field with the format shown below:
```json
  "variable": "speed",
  "value": 10,
  "location": {
    "lat": 42.2974279,
    "lng": -85.628292
TagoIO converts latitude and longitude fields to the specific format required, so you don't need to perform any conversions. To accomplish this, you only need to have the variables named `latitude` and `longitude` or `lat` and `lng`. TagoIO will automatically read these variables and create a new variable called `location`.
After your device is sending latitude and longitude information to TagoIO:
- Create a dashboard.
- Add a [Map widget](/docs/tagoio/widgets/map-and-location/map-widget/).
- Look for the device and add the variable `location` inside the Map widget.
