title: "Adeunis with Sigfox"
description: "This article explains how TagoIO integrates with Adeunis devices via the Sigfox backend, how incoming data is parsed and made available for Analysis, and how to add an Adeunis device in TagoIO."
# Adeunis with Sigfox
TagoIO supports most Adeunis devices by providing an integration with the Sigfox
backend. Incoming messages from Adeunis devices are parsed in real time so
measured variables are extracted and made available to TagoIO for display in
widgets and for processing.
![Adeunis + Sigfox + TagoIO diagram](/docs_imagem/tagoio/tutorials-adeunis-sigfox-network-architecture-diagram.png)
All data sent by your device will be readily available to be displayed in
widgets and processed in your [Analysis](/docs/tagoio/analysis/).
:::info
You can check if a parser script was added to your device under the tab "Payload
Parser".
## Adding a device
To add an Adeunis device in TagoIO:
1. Go to [Devices](https://tago.io/devices).
2. Click on "+ New Device".
3. Filter the list by network and select "Sigfox".
4. Pick your specific Adeunis device from the list.
### Integrate your Adeunis with TagoIO
1. Turn on your Adeunis device and wait for the data to reach your TagoIO Device.
2. Each time the device sends data, the parser will be executed automatically,
   extracting the measured variables and sending them to the device.
3. The extracted data is then available in widgets, dashboards, and can be
   processed further.
You can start building **dashboards** immediately:
[Dashboard Overview](/docs/tagoio/dashboards/).
You can also create **notifications** or write advanced **scripts** to process the data:
- Notifications: [Notifications](/docs/tagoio/actions/)
- Scripts:
  [Creating Analysis Scripts](/docs/tagoio/analysis/creating-analysis.md)
If you have questions about configuring your account for Sigfox and TagoIO, read
the article about [SigFox](/docs/tagoio/integrations/networks/sigfox.md).
