title: "Console for Debug"
description: "A short guide explaining how to use the Analysis console to monitor script variables, view errors and log output, and clear the console in TagoIO."
# Console for Debug
Use the console to monitor the variables and status of your script. You can see any errors or text generated by console.log (or context.log). This console is a simple and useful debugging tool.
## Console UI
![Console view showing the Console tab and Clear Console button](/docs_imagem/tagoio/analysis-console-log-error-output.png)
- Console Area: displays errors and any output generated by your script.
- Clear Button: clears all output shown in the console area.
- Download Button: downloads the console output as a text file.
:::tip
[TagoAI](/docs/tagoio/tago-ai/) can also help debug your script: ask about errors or unexpected behavior and it will use the Analysis console as context.
## How it works
1. Console Screen: any errors or responses generated by console.log (or context.log) will appear here.
2. Clear Console: clears everything currently shown in the console screen.
3. Download Console: downloads the console output as a text file.
## Example
Use console.log in your Analysis script to write to the console:
```javascript
console.log("Debug message:", myVariable);
You can learn more about Analysis [here](/docs/tagoio/analysis/).
